Configuring IPMDAR Templates
Configure IPMDAR templates to define data exchange options for exporting to IPMDAR format.
To configure IPMDAR templates:
  1. On the "" Navigation Menu, expand "" Projects and click EPS.
  2. On the EPS page:
    1. Click the Actions"" menu and select Import/Export Projects.
    2. In the Import/Export Projects dialog box, click the Export tab.
    3. On the Export tab:
      • Select IPMDAR from the Export Type list.
      • Select a project.
      • Click Manage Templates.
    4. In the Manage IPMDAR Templates dialog box:
      • Click a template or click "" Add to create a new template.
    5. In the IPMDAR Template dialog box:
      • Configure the lists, options, and fields on each tab.
      • Click Save.
        Once data is exported from P6 into another project management tool, dates, durations and other data may no longer reflect those in P6 if the other project management tool recalculates this data.
