Configuring UN/CEFACT Templates
Configure UN/CEFACT templates to define data exchange options for exporting to UN/CEFACT XML Format 6.
To configure UN/CEFACT templates:
  1. On the "" Navigation Menu, expand "" Projects and click EPS.
  2. On the EPS page:
    1. Click the Actions"" menu and select Import/Export Projects.
    2. In the Import/Export Projects dialog box, click the Export tab.
    3. On the Export tab:
      • Select UN/CEFACT XML Format 6 from the Export Type list.
      • Select a project.
      • Click Manage Templates.
    4. In the Manage UN/CEFACT Templates dialog box:
      • Click a template or click "" Add to create a new template.
    5. In the UN/CEFACT Template dialog box:
      • Configure the lists, options, and fields on each tab.
      • Click Save.
        Once data is exported from P6 into another project management tool, dates, durations and other data may no longer reflect those in P6 if the other project management tool recalculates this data.
