Configuring Project Code Values
Configure project code values to describe and weigh the importance of the code value.
To configure project code values:
- On the
Navigation Menu, expand
Administration and click Enterprise Data. - On the Enterprise Data page, expand Projects and click Project Codes.
- On the Project Codes page:
- Expand a project code.
- Select the code value you want to configure.
- In the Name field, double-click and type a name for the code value.
- In the Description field, double-click and type a brief narrative about the code value.
- In the Weight field, double-click and type a value.
- Click Save.
Tip:
The weight reflects the ranking of this value against other values in the project code.
