Configuring Project Codes
Configure project codes to add security, code weight, and a description to the code.
To configure a project code:
  1. On the "" Navigation Menu, expand "" Administration and click Enterprise Data.
  2. On the Enterprise Data page, expand Projects and click Project Codes.
  3. On the Project Codes page:
    1. Select the code you want to configure.
    2. In the Secure field, select the option to make the code read-only for users without the necessary security privileges to make changes.
    3. In the Weight field, double-click and type the project code weight.
    4. In the Maximum Code Value Weight field, double-click and type a value.
    5. Click Save.
Tip:
  • You can designate a project code as secure only if you have the appropriate security privilege; otherwise the Secure option does not display.
  • The Weight of a project code reflects the ranking of the code against other project codes.
