Creating Project Code Values
Create project code values to group, sort, and filter project data.
To create project code values:
  1. On the "" Navigation Menu, expand "" Administration and click Enterprise Data.
  2. On the Enterprise Data page, expand Projects and click Project Codes.
  3. On the Project Codes page:
    1. Select a code or code value.
      : You might have to expand an EPS node or Project before you see the codes and code values.
    2. Click "" Context and select Add Code Value or Add Child Code Value.
    3. In the Name field, double-click and type a unique code value name.
    4. In the Description field, double-click and type a brief narrative about the code value.
    5. Move the code value to the correct location in the list by clicking "" Context and selecting Move Up, Move Down, Move Left, or Move Right.
    6. In the Weight field, double-click and type a value.
    7. Click Save.
Tip:
  • Project code values at the same level are siblings. Subordinate project code values are children.
  • The weight reflects the ranking of a code value against other values in the project code.
