Configuring the Resources Assignments Gantt Chart Bars
Configure the bar settings for the Gantt chart view on the Resources Assignments page. You can set features for up to three bars per assignment.
To configure the resource assignments Gantt chart bars:
- On the
Navigation Menu, expand
Resources and click Assignments. - On the Assignments page, click
Customize View. - In the Customize View dialog box:
