Viewing Resource Assignments in a Gantt Chart
View the Gantt chart for a graphical display of the start and end dates for resource assignments.
To view resource assignment activities in a Gantt chart:
  1. On the "" Navigation Menu, expand "" Resources and click Assignments.
  2. On the Assignments page, click "" Gantt View.
    • To view the start and end dates of assignments for a particular resource, double-click the Gantt next to the row in the resource table that contains the resource.
    • To change the timescale on the Gantt, right-click the dates at the top of the Gantt and choose another timescale.
Tip:
To customize the list of resources displayed in the table, click the Filters menu and choose to use an existing filter, or create a new filter.
