Working with Resource Assignments in the Gantt Chart
The Resources Assignments area enables you to view a customized list of resources based on the filters you assign to the view. You can extend this customized view by displaying the Gantt chart, which is a graphical display of the start and end dates for the resource assignments.
To customize the resource assignments view in the Gantt chart, you can:
  • Customize the Gantt bar type, height, color, label, and position.
  • Set the timescale and gray scale for non-worked hours.
  • Modify the start and end dates for assignments.
