Copying and Pasting Activities
You can copy and paste activities. When you copy and paste activities, you can control which data types are copied to the new activities.
To copy and paste activities:
  1. On the "" Navigation Menu, expand "" Projects and click Activities.
  2. On the Activities page:
    1. Select one or more activities.
    2. Click "" Context and select Copy.
    3. Select a single activity in the grouping band that you want to paste the new activities into, or if the grouping band is empty, select the grouping band itself.
    4. Click "" Context and select Paste.
    5. In the Copy Activity Options dialog box:
      • Select the data items to be copied.
      • Click OK.
    6. Click Save.
      • Hold down the Ctrl key while clicking to select multiple rows in a table. Hold down the Shift key to select contiguous rows.
      • When you copy an activity, the following data items are not copied: Issues, Assignment UDF values, Expense UDF values, Step UDF values, Activity Feedback, and Status Update History (from Team Member interfaces only)
      • If you copy a WBS that includes activities, then Issues, Assignment UDF values, Expense UDF values, and Step UDF values are copied for each activity.
      • Risk Assignments are copied for each activity when you copy activities or WBS elements to the same project. If you copy activities or WBS elements to a different project, Risk Assignments are not copied.
