Creating Activities
Create activities to define a more detailed breakdown of projects or WBSs.
To create activities:
  1. On the "" Navigation Menu, expand "" Projects and click Activities.
  2. On the Activities page:
    1. Click the "" Context menu and select Add Activity.
    2. Enter an ID in the ID/Code field.
      The ID/code must be unique in the project.
    3. Enter a name in the Name field.
    4. Click Save.
Tip:
  • Right-click a project, WBS, or activity and select Add Activity to quickly add an activity.You can also right click in the background of the Gantt view and select Add Activity.
  • The application automatically names new activities New Activity.
  • The default limit allows you to create up to 5000 activities per activity view.
