Creating Activity UDFs
Create activity user defined fields (UDFs) if the predefined fields do not meet your needs.
To create an activity UDF:
- On the
Navigation Menu, expand
Administration and click Enterprise Data. - On the Enterprise Data page, expand Activities and click Activity UDFs.
- On the Activity UDFs page:
- Click
Add. - In the User Defined Field, double-click and type a name.
- In the Data Type field, choose a type from the list.
- Click Save.
- Click
Tip:
- If you intend to use reporting software, avoid using commas when creating data other than Project names. The way that data is passed to some reporting software can cause a comma to be interpreted as a delimiter between data items.
- You can create manual UDFs quickly from any UDF detail window, by clicking Assign and then clicking Add in the Assign UDFs dialog box.
- The software automatically creates a UDF called MSP Activity ID the first time anyone exports a project to Microsoft Project format. This UDF is hidden and cannot be modified. You should avoid creating a UDF with that name.
