Creating Expense UDFs
Create expense user defined fields (UDFs) if the predefined fields do not meet your needs.
To create an expense UDF:
- On the
Navigation Menu, expand
Administration and click Enterprise Data. - On the Enterprise Data page, expand Activities and click Expense UDFs.
- On the Expense UDFs page:
- Click
Add. - In the User Defined Field, double-click and type a name.
- In the Data Type field, choose a type from the list.
- Click Save.
- Click
Tip:
If you intend to use reporting software, avoid using commas when creating data other than Project names. The way that data is passed to some reporting software can cause a comma to be interpreted as a delimiter between data items.
