Creating Step UDFs
Create step user defined fields (UDFs) if the predefined fields do not meet your needs.
To create a step UDF:
  1. On the "" Navigation Menu, expand "" Administration and click Enterprise Data.
  2. On the Enterprise Data page, expand Activities and click Step UDFs.
  3. On the Step UDFs page:
    1. Click "" Add.
    2. In the User Defined Field, double-click and type a name.
    3. In the Data Type field, choose a type from the list.
    4. Click Save.
Tip:
If you intend to use reporting software, avoid using commas when creating data other than Project names. The way that data is passed to some reporting software can cause a comma to be interpreted as a delimiter between data items.
