Creating Assignment Codes
Create assignment codes to group and arrange resource and role assignments.
To create assignment codes:
- On the
Navigation Menu, expand
Administration and click Enterprise Data. - On the Enterprise Data page, expand Resources and click Assignment Codes.
- On the Assignment Codes page:
- Click
Context and select Add Code. - In the Name field, double-click and type a unique code name.
- In the Secure field, select the option to make the code read-only for users without the necessary security privileges to make changes.
- Move the code to the correct location in the list by clicking
Context and selecting Move Up, Move Down, Move Left, or Move Right. - In the Maximum Length field, double-click and click the up or down arrow to specify the maximum length for resource code value names.
- Click Save.
- Click
Tip:
You can designate an assignment code as secure only if you have the appropriate security privilege; otherwise, this option does not display.
