Creating Assignment Code Values
Create assignment code values to represent variations within the larger scope of the assignment code.
To create assignment code values:
  1. On the "" Navigation Menu, expand "" Administration and click Enterprise Data.
  2. On the Enterprise Data page, expand Resources and click Assignment Codes.
  3. On the Assignment Codes page:
    1. Select a code or code value.
      : You might have to expand an EPS node or Project before you see the codes and code values.
    2. Click "" Context and select Add Code Value or Add Child Code Value.
    3. In the Name field, double-click and type a unique code value name.
    4. In the Description field, double-click and type a brief narrative about the code value.
    5. Move the code value to the correct location in the list by clicking "" Context and selecting Move Up, Move Down, Move Left, or Move Right.
    6. Click Save.
