Creating a WBS from a Template
You can add a predefined WBS element from a template to a project.
To add a WBS from template:
- On the
Navigation Menu, expand
Projects and click Activities. - On the Activities page:
- In the Activity Table, select a project or WBS element and select
Context then select Add WBS from Template. - In the Select WBS dialog box, select a WBS from the list of templates and click Select.
- In the Copy WBS Options dialog box, select the data items you want to include with the pasted WBS element and click OK.
Tip:
- The application automatically assigns the WBS element a name based upon the selected WBS.
- The new WBS element is created and saved automatically as a child of the selected WBS element.
