Configuring General WBS Information
Configure WBS information in to account for any updates or changes made to the WBS.
To configure general WBS information:
- On the
Navigation Menu, expand
Projects and click Activities. - On the Activities page, select a WBS and click the General detail window.
- In the General detail window:
- Add or remove columns as needed to configure to the detail window.
- Select an option or enter a value for each field.
- Save your changes.
