Creating Document Templates
If P6 is configured to use the content repository, you can create document templates that you can use as a foundation when adding new documents.
To create document templates:
  1. On the "" Navigation Menu, expand "" Projects and click Documents.
  2. On the Documents page, click the Project tab.
  3. On the Project tab, select a project and click """" Add Options and select Create New Template.
  4. In the Create New Template dialog box:
    1. Select a file and select Open.
    2. Select Upload.
  5. On the Project tab, click the General tab.
  6. On the General tab:
    1. Enter a name in the Title field.
    2. In the Security Policy list:
      • Select Read Only to prevent other users from editing the template.
      • Select Shared to allow other users to view, move, edit, and delete the template.
      • Select Personal to prevent other users from accessing the template.
    3. Click Save.
Tip:
  • You can also create document templates from the My Documents portlet of the Dashboards page.
  • You can make a document you have already uploaded into a template by selecting the Template Document option on the General tab.
