Copying Documents from Existing Templates
If P6 is configured to use the content repository, you can copy documents from templates to add a new document based on an existing template.
To copy documents from templates:
- On the
Navigation Menu, expand
Projects and click Documents. - On the Documents page, click the Project tab.
- On the Project tab, select a project and click
Add Options and select Copy from existing template. - In the Select a Template to Copy From dialog box, select a template and click OK.
- On the Project tab:
- Click the General tab and enter a name in the Title field.
- Click and configure each tab as necessary.
- Click Save.
Tip:
You can also create document templates from the My Documents portlet of the Dashboards page.
