Creating Expense Categories
Create an expense category to organize and track various expense types within an organization.
To create expense categories:
  1. On the "" Navigation Menu, expand "" Administration and click Enterprise Data.
  2. On the Enterprise Data page, expand Activities and click Expense Categories.
  3. On the Expense Categories page:
    1. Click "" Add.
    2. In the Category field, double-click and type a name.
    3. Click Save.
Tip:
  • To change an expense category, double-click it, then type a new name. The change applies to all projects to which the expense item is assigned.
  • To change the order in which an expense category is displayed, select it, then click "" Context and select Move Up or Move Down.
