Creating Step Templates
Create step templates to specify reusable sets of steps common to many activities. This task represents the minimum steps required to create a step template. You can also configure a step template to add, delete, or arrange the steps assigned to a template.
To create step templates:
- On the
Navigation Menu, expand
Administration and click Enterprise Data. - On the Enterprise Data page, expand Activities and click Step Templates.
- On the Step Templates page:
- Click
Add. - In the Template Name field, double-click and type a name.
- Click Save.
- Click
