Creating Import Templates for Importing Resources
Create a Microsoft Excel template to use when importing resource data.
To create an import template:
Tip:
When entering resource data in the Excel spreadsheet:
- Be sure to include a Resource ID and Resource Name for each resource, otherwise all data for that resource is excluded from the import.
- For fields that include a check box in the application, enter the values true/false, or y/n. The default system setting values are applied to these fields if no value is entered. The following is a list of the check box fields available for import along with their default values:
- Active = true
- Calculate Costs from Units = true
- Overtime Allowed = false
