Importing Resource Data
Use this procedure to import resource data from a Microsoft Excel (.xlss) spreadsheet.
You must create an import template and populate the Excel file with resource data before you can perform this procedure.
To import resource data:
  1. On the "" Navigation Menu, expand "" Resources and click Administration.
  2. On the Resources page, click Resources.
  3. On the Resources tab, click Actions "" and select Import from Excel.
  4. In the Import Resources dialog box, click "" Browse in the Import File field.
  5. In the File Upload dialog box, browse to the file you want to import and click Open.
  6. In the Import Resources dialog box, click Import.
    If errors are detected during the import, click View the log file for more details in the Information dialog box. If you want to save the log file, click Save File.
