Creating Issue Codes
Create issue codes to organize project issues in a way that is meaningful to your organization.
To create an issue code:
  1. On the "" Navigation Menu, expand "" Administration and click Enterprise Data.
  2. On the Enterprise Data page, expand Issues and click Issue Codes.
  3. On the Issue Codes page:
    1. Click "" Context and select Add Code.
    2. In the Name field, double-click and type a unique code name.
    3. In the Secure field, select the option to make the code read-only for users without the necessary security privileges to make changes.
    4. Click Save.
Tip:
You can designate an issue code as secure only if you have the appropriate security privilege; otherwise, this option does not appear.
