Creating Issue Code Values
Create issue code values to represent variations within the larger scope of the issue code.
To create an issue code value:
  1. On the "" Navigation Menu, expand "" Administration and click Enterprise Data.
  2. On the Enterprise Data page, expand Issues and click Issue Codes.
  3. On the Issue Codes page:
    1. Select a code or code value.
    2. Click "" Context and select Add Code Value.
    3. In the Name field, double-click and type a unique code value name.
    4. In the Description field, double-click and type a brief narrative about the code value.
    5. Move the code value to the correct location in the list by clicking "" Context and selecting Move Up or Move Down.
    6. Click Save.
Tip:
Issue code values at the same level are siblings. Subordinate issue code values are children.
