Creating Projects from Existing Projects or Templates
In place of making a project from scratch, you can use a template or a copy of an existing project as a starting point.
To create a project from an existing project or template:
- On the
Navigation Menu, expand
Projects and click EPS. - On the EPS page:
Tip:
- To configure advanced options, you must select a project to copy. This will enable the Advanced tab. If you select to copy a template, the Advanced tab will not be enabled.
- You can also right-click the table, select Add Project, and follow steps 4 and 5 to create a project from an existing project or template.
- You cannot copy from a project unless you have the privilege to view costs for a project.
