Creating Project Templates from Existing Projects or Templates
In place of making a project from scratch, you can use a template or a copy of an existing project as a starting point.
To create a project from an existing project or template:
- On the
Navigation Menu, expand
Projects and click EPS. - On the EPS page:
Tip:
If you choose to copy from an existing project, select either the Use Actual Costs and Units or Use Planned Costs and Units option. If you select to copy from a template, the application will disable the Use Actual Costs and Units option.
