Deleting Projects or EPS Elements
Delete projects or EPS elements when they are no longer necessary.
To delete a project or EPS element:
  1. On the "" Navigation Menu, expand "" Projects and click EPS.
  2. On the EPS page:
    1. Select a project or EPS element.
    2. Click "" Context and select Delete.
    3. In the Confirm dialog box, click Yes.
    4. Click Save.
