Customizing Detail Windows
You can customize which detail windows appear on the EPS page or Activities page.
To customize detail windows:
- On the
Navigation Menu, expand
Projects and click Activities or EPS. - On the Activities or EPS page:
- Select a view from the Views list.
- Click
Show/Hide Tabs and select
Show/
Hide for each tab you want to show or hide. - Click Save View.
Tip:
- Click and drag detail windows to change their order.
- You can save or cancel the view changes you made to the detail windows. These changes will only be saved for the view selected in the Activity or EPS View list.
