Duration Percent
Duration Percent field
The percent complete of the activity duration.
The planned duration is taken from the current plan, not from the baseline.
The type of percent you see depends on the percent complete type you select for the activity in the General section of the Activity Form page.
Calculated as (Planned Duration minus Remaining Duration) divided by Planned Duration multiplied by 100. Always in the range 0 to 100.
