Exporting Projects to a Zip File
You can export projects to a compressed file. The resulting zip file contains a single Primavera XML file that describes the projects you selected to export.
To export projects to a compressed file:
  1. On the "" Navigation Menu, expand "" Projects and click EPS.
  2. On the EPS page:
    1. Click the Actions"" menu and select Import/Export Projects.
    2. In the Import/ExportProject dialog box, click the Export tab.
    3. On the Export tab:
      • In the Export Type field, select Primavera XML.
      • Select the Export to ZIP option.
      • Click "" Add Project..., and in the Select Project dialog box select the projects to export then click Select.
      • In the Baselines field, click and select which baselines you want to include with the export.
      • Click Export.
Tip:
To download the exported file, click the link in the View Service Status tab or Notifications dialog box.
