Exporting Projects to Excel
You can export the list of projects in your EPS view to a Microsoft Excel (.xlsx) file.
To export projects:
- On the
Navigation Menu, expand
Projects and click EPS. - On the EPS page:
- Select an EPS view from the Views list.
- Configure the EPS view to determine what data is exported.
- Click
Download. - In the Opening dialog box, choose whether to open or save the file.
Tip:
All data is exported as it appears in the current EPS view.
