Exporting Projects using CPP
You can export projects to locations outside of P6 using CPP Format. The CPP format export generates a collection of JSON files which constitute the CPP data.
To export projects using CPP:
- On the
Navigation Menu, expand
Projects and click EPS. - On the EPS page:
Tip:
You can see the status and download the export file in the View Service Status dialog box.
