Exporting Projects using IPMDAR
You can export projects to locations outside of P6 using IPMDAR Format. The IPMDAR export generates a collection of JSON files which constitute the IPMDAR data.
To export projects using IPMDAR:
  1. On the "" Navigation Menu, expand "" Projects and click EPS.
  2. On the EPS page:
    1. Click the Actions"" menu and select Import/Export Projects.
    2. In the Import/Export Project dialog box, click the Export tab.
    3. On the Export tab:
      • In the Export Type field, select IPMDAR.
      • In the Project field, click "" Select and select a project from the dialog box.
      • In the Template field, select a template.
        If you need to create or modify a template, click the Manage Templates button.
      • Click Export.
Tip:
You can see the status of the import in the View Service Status dialog box.
