Exporting Projects using UN/CEFACT XML
You can export projects to locations outside of P6 using UN/CEFACT XML Format 6.
To export projects using UN/CEFACT XML Format 6:
- On the
Navigation Menu, expand
Projects and click EPS. - On the EPS page:
Tip:
You can see the status of the import in the View Service Status dialog box.
