Exporting Projects using Primavera XER
You can export projects to Primavera XER format to share them with P6 Professional.
To export projects using Primavera XER format:
  1. On the "" Navigation Menu, expand "" Projects and click EPS.
  2. On the EPS page:
    1. Click the Actions"" menu and select Import/Export Projects.
    2. In the Import/ExportProject dialog box, click the Export tab.
    3. On the Export tab:
      • In the Export Type list select Primavera XER.
      • In the Project field, click "" Select and select a project to export.
      • In the Template list select a template to use.
        If you need to create a template or modify an existing template, click Manage Templates.
      • Click Export.
Tip:
  • You can manage XER and XML import templates separately from the importing and exporting process using the Manage Import Templates option on the Actions"" menu of the EPS page.
  • You can see the status of the import in the View Service Status dialog box.
