Importing Projects using Microsoft Project XML
You can import projects using the Microsoft Project XML format to create and manage them as new projects in P6.
- To import a project via XML using P6 or P6 Professional, your user account's Resource Access field must be set to All Resources. This change can be made temporarily and then restored on the Users pane on the User Access page.
- Avoid using the pipe character ( | ), or brackets ( < or > ) in the Project Name.
To import projects using the Microsoft Project XML format:
- On the
Navigation Menu, expand
Projects and click EPS. - On the EPS page:
Tip:
- You can see the status of the import in the View Service Status dialog box.
- You can import multiple projects as one file using Microsoft Project XML format.
