Personal Information Tab of the My Preferences Page
Overview
Use this tab to see the personal information stored about you in P6 EPPM. You cannot edit this information.
Screen Elements
Forget User Acceptance button
Resets your consent status to Not Responded.
Reset User Preferences button
Resets all your preferences to the defaults.
Login Name field
Your login name.
Personal Name field
The personal name for your user account. This name might be a nickname, full name, reference to a role or department, or include any information recognized by your organization to identify you as the user of this account.
Phone field
Your telephone number.
Email field
The Email address for your user account.
Associated Resource field
The resource associated with your user account. Depending on the modules used by your organization, this is the resource used to pair your user account with timesheets, personal calendars, and assignments (for email or phone updates).
Getting Here
  1. Click the User menu and select My Preferences.
  2. On the My Preferences page, click the Personal Information tab.
