Pie Chart Settings Area
The Pie Chart settings area displays configurable options for viewing portfolio data in a pie chart view. Use the following fields to modify your pie chart view.
Screen Elements
Data list
Select a field of data to display in the Pie Chart view. Select an option from the following categories:
Budget: The fields that display budget information.
Cost: The fields that display cost information.
Durations: The fields that display duration information.
Earned Value: The fields that display earned value information.
General: The fields that display general information.
Number of Activities: The fields that display information on activity numbers.
Percent Complete: The fields that display information on percent complete.
Units: The fields that display information on units.
User Defined: The additional fields created to capture important information that is not available from the standard fields.
Group By list
Select a field value to determine your preferred option to group your data.
Color Theme list
Determines colors displayed on the chart. Select a predefined or user-defined color theme.
Pie Data Label option
Determines whether to show the Pie Data Label.
Group by label option
Determines whether to show the Group by label.
Show percentage option
Determines whether to show percentage on the chart.
Show 3-D option
Determines whether to show a 3-Dimensional view of chart.
