Portfolio Analysis Toolbar
The Portfolio Analysis toolbar includes the following:
Screen Elements
Save
Saves any new or modified entries to the database.
Save As
Enables you to save the current item as a new instance with a new name.
Cancel
Cancels any pending changes and reverts back to the last saved state.
Create Portfolio View
Enables you to create a new portfolio view based on either an existing view or new attributes you define.
Maximize
Maximizes the current chart in the work area, temporarily hiding the vertical or horizontal compare view.
Print Preview
Enables you to view a preview of the printed output. You can then decide to print or make additional changes.
Scorecard View
When you choose a scorecard view, the Portfolio Analysis toolbar displays the following additional options:
Add Project
Enables you to add a new project to the scorecard.
DeleteProject
Deletes the selected project from the view permanently.
Create Portfolio from Selected Projects
Redirects you to the Create Portfolio page.
Waterline
Opens the Waterline tab of the Customize Scorecard dialog box where you can override any previously applied grouping and sorting and instead define a single waterline level parameter and new sort order. Use the waterline to assess a simple visual depiction of the projects that satisfy your criteria, the ones floating above the waterline, versus those that do not, the ones sinking below the waterline.
- If you choose to compare portfolios using a calculatedProject Score, the analysis attempts to include all code values for the selected project codes, even unassigned ones. Assign values to all project codes before comparing project scores.
- When a waterline based on Project Score is applied to a scorecard, the application uses actual scores for comparing top-level project group scores, and uses averages for calculating project group scores within the hierarchy. The application re-calculates all project scores at the top level because it provides a more accurate result than using an average of lower-level averages.
Export Spreadsheet
Exports all data as it appears in the current view to a Microsoft Excel spreadsheet (.xlsx) file. Customize the rows to display only the data you want to export.
