Portfolios Navigation Bar
Click a portfolio toolbar icon to open its corresponding page.
Screen Elements
Portfolio Analysis
Enables you to analyze portfolio data, conduct side-by-side comparisons of two project groups, and apply waterline analysis techniques to assist with executive-level critical decision making.
Capacity Planning
Enables you to analyze role allocation and cost over time. Multiple chart formats display role allocation for the projects and roles you select, enabling you to quickly identify areas of under or over allocation.
Performance Status
Enables you to view the summarized schedule and cost or labor unit data based on the performance metric you select.
