Scorecard Settings Area
The Scorecard settings area displays configurable options for viewing portfolio data in a Scorecard. Use the following fields to modify your scorecard view.
Screen Elements
Group By list
Select a field value to determine your preferred option to group your data.
Customize link
Displays customize scorecard dialog box. See Customize Scorecard Dialog Box.
