Selecting Values from "Select a Value" Dialog Boxes
To assist you in selecting from a constrained list of available values, the application will often display Select a Value dialog boxes. Use these special dialog boxes to search for potential matching values and select one or more specific values appropriate for the current field.
Although commonly used throughout the application, each dialog box can contain unique options.
To select a value from a Select a Value dialog box:
- Enter any search criteria to reduce the number of values shown.
- Select a value in the list. If grouped in a hierarchy, expand a group to view the values.
- Click OK, Select or Assign.
- Repeat these steps to select additional values if necessary.
- When finished, click Close.
- If applicable, click Save, Save and Close or OK.
