Sending Email to Project Resources
You can send email to the resources listed for an open project.
To send Email to project resources:
- On the
Navigation Menu, expand
Dashboard. - On the Dashboards page, select a dashboard.
- On the dashboard, expand the Communication Center portlet.
- In the Communication Center portlet:
- Click Expand
to expand a project and view its assigned resources. - Select the check box for each resource you want to add to the mailing list. Each name you select will appear in the Email message's distribution list (the To: field).
- Click the Send an Email link.
- Click Expand
- In the Email dialog box:
- Edit the recipients, subject, and message text if needed.
- Click Send Email.
Tip:
- Select the check box next to the project name to automatically select all resources listed. Clear the same check box to automatically clear all resources.
- You must have an Email address listed in your user account to send Email.
