Sending Email to Resource Teams
You can send email to an entire resource team of your choosing.
To send Email to a resource team:
  1. On the "" Navigation Menu, expand "" Dashboard.
  2. On the Dashboards page, select a dashboard.
  3. On the dashboard, expand the Resource Team Summary portlet:
  4. In the Resource Team Summary portlet:
    1. Click "" Filter by and select the team to which you want to send an Email.
    2. Click "" email resource team.
  5. In the Email dialog box:
    1. Edit the recipient list, message, and subject as needed.
    2. Click Send Email.
Tip:
You must have an Email address listed in you user profile to send an Email.
