Summarizing Projects
Summarize projects to maintain up-to-date project data.
To summarize projects:
  1. On the "" Navigation Menu, expand "" Projects and click EPS.
  2. On the EPS page:
    1. Select a project or EPS node.
    2. Click Actions "" and select Summarize Projects.
Tip:
  • Using the Project Scheduled Services page, you can schedule the application to automatically summarize projects on a periodic basis.
  • You can also delete summarized data if it is no longer needed, using the Delete Summarized Data item on the Click Actions "" menu.
  • These services are removed from the database based on the ASAP Cleanup Rate your P6 administrator specifies on the Configurations tab in P6 Administrator application. Once the time is met all ASAP jobs that have a status other than running or delegated will be removed from the table automatically. Running and delegated jobs will be removed if they are older than the cleanup rate or if they are older than one day, whichever is greater.
