To Date: Labor Units
To Date: Labor Units field
Determines project performance by calculating the variance between the actual and the scheduled labor units. This value is accompanied by a convenient visual indicator mapped to performance thresholds you can define.
Calculated as Earned Value Labor Units minus Actual Labor Units.
