Using Visual Indicators
Indicators are a special type of user-defined field (UDF) that enable you or other users to select icons (such as
, and
) to display as values in columns to highlight specific activities, activity steps, activity resource assignments, documents, projects, resources, risks, WBS elements, expenses, and issues.
To configure and apply user-defined indicators:
