Viewing Role Usage
Use the Role view to view detailed role assignment information in histogram and spreadsheet format.
- On the
Navigation Menu, expand
Resources and click Analysis. - On the Analysis page, click the Role button.
- In the Role view:
- In the Group By list, choose to view roles by Role Hierarchy, Role Team, or by a role or assignment code.
- Click a role name.
- Click
Customize View.
- In the Customize View dialog box:
Tip:
- The role usage data displayed on the Role Usage tab is based on published data, so it reflects values as of the last date the project was published. Assignment changes within a project after that date will not be reflected until the project is republished. However, an option on the My Preferences page allows you to display stored financial period data in this chart.
- A setting in your preferences determines whether the role limit includes the limits of resources assigned that role, but that are currently set as inactive.
- An application level setting determines whether cost spreads account for changes in resource and role rates over time.
