Default Bridge Settings when Publishing PPM Items
The defaults step of the Bridge Server Settings Wizard supports setting the mapping mode of the bridge and the addition of item reference information to the newly created project plan.
This step also includes the P6 project field to be hyperlinked to PPM field which will contain the URL to the PPM item that is linked to the P6 project, and the default EPS node for new projects field for determining the EPS location of new projects.
